jaykool_56 Posted April 20, 2006 Report Share Posted April 20, 2006 :o :( >:( :( :o 8) ??? ::) :P :-[ :-X :-\ :-* :'( :'( :-Xmga tol muzta!how can i get a negative supply frm a positive and ground power supply?this is what i want i need to produce a (-) prom the (+)and (0) supply.if you have pls share with me thanks!! Quote Link to comment Share on other sites More sharing options...
MrHeckles Posted April 20, 2006 Report Share Posted April 20, 2006 I have found the ICL7660 voltage converter chip to be very helpful.Here is a link to a datasheet for it.http://www.alldatasheet.com/datasheet-pdf/pdf/67436/INTERSIL/ICL7660.html Quote Link to comment Share on other sites More sharing options...
audioguru Posted April 20, 2006 Report Share Posted April 20, 2006 A 555 oscillator that is driving a capacitive-coupled rectifier will give much more negative output current than an ICL7660, but has a two-diodes voltage drop.A car stereo power amp that has an oscillator driving it and it is driving a capacitive-coupled rectifier will give much more negative output current than either of the above. Quote Link to comment Share on other sites More sharing options...
Muhammad Abu Bakar Posted April 23, 2006 Report Share Posted April 23, 2006 If u r powering the sircuit from AC supply, this circuit might help u for dual supply operation. Quote Link to comment Share on other sites More sharing options...
Guest Kasamiko Posted April 23, 2006 Report Share Posted April 23, 2006 :o :( >:( :( :o 8) ??? ::) :P :-[ :-X :-\ :-* :'( :'( :-Xmga tol muzta!how can i get a negative supply frm a positive and ground power supply?this is what i want i need to produce a (-) prom the (+)and (0) supply.if you have pls share with me thanks!!Please used English language only..I have some ICL7660 on stock here..Where you in the Philippines? PM me for some info..Regards..rhonn ;) ;) Quote Link to comment Share on other sites More sharing options...
