walid Posted May 19, 2006 Report Posted May 19, 2006 (1) I read carefully the CM8870 datasheets but I can't conclude that it can receive the FM signal directly or it must be connected to a separated FM receiver please tell me(2) I hardly got the datasheets of CM8870/70C, but i really have CM8870PI Is there any difference?thanx Quote
audioguru Posted May 19, 2006 Report Posted May 19, 2006 Hi Walid,It is just a DTMF tones decoder. It has nothing to do with a radio.Get a good datasheet from www.datasheetarchive.com .If you use an ordinary FM broadcast band radio then it has de-emphasis and the transmitter that you use must have a matching pre-emphasis. Quote
walid Posted May 20, 2006 Author Report Posted May 20, 2006 It is just a DTMF tones decoder. It has nothing to do with a radio.i understand that it require a separate FM receiverGet a good datasheet from www.datasheetarchive.com .i use this link but i have not any resultsbut in this http://www.alldatasheet.com/ i faound manyIf you use an ordinary FM broadcast band radio then it has de-emphasis and the transmitter that you use must have a matching pre-emphasis.i'm not understand this statementthank you Quote
audioguru Posted May 20, 2006 Report Posted May 20, 2006 Hi Walid,To reduce hiss, FM stations and TV stations use pre-emphasis for their audio transmission, and FM receivers have a corresponding de-emphasis.Pre-emphasis boosts high audio frequencies and the de-emphasis cuts them back to normal and also cuts hiss.DTMF needs a frequency response that is fairly flat, but if you don't use pre-emphasis in its transmission then a receiver's de-emphasis will cut high tones frequencies too much. Quote
walid Posted May 21, 2006 Author Report Posted May 21, 2006 OK Mr audioguruI may understand the general aspect of what u said butcan u give me an example about this especially on your FM transmitter circuit.where the subcircuit or the parts that do the pre-emphasis also in the receiver where it be placed in the whole circuitthank u audioguru Quote
