dark_rebel Posted May 30, 2006 Report Posted May 30, 2006 Hey, Im working on a project to adapt a surveillance system. Currently there are 8 cameras going into two monitors. It is an ADT system and the cameras connect to the monitors using rj14 6 pin connectors (ive found that pin 5 is + 9-15 V and pin 6 is ground). The guy wants to keep his existing 8 cameras but switch the 2 monitors for a security DVR which uses BNC video inputs and RCA audio inputs.Ive built a 12V 2 A PS and the power bus for all 8 cameras. But now the tricky part is getting an analog video stream out of the cameras. I thought that they were outputting analog video but i cant get any video onto a regular TV. If ANYONE can provide any useful info i would be VERY greatful. anything from ADT pinout, or what i can do to get an analog video sinal from the camera. Thank you in advanced.PS. . . im at work but i will post the camera model when i get home. That might be useful. Quote
dark_rebel Posted May 31, 2006 Author Report Posted May 31, 2006 ok... i got the model number.its an ADT A-C4CM/4on the bottom it says 15V DC 3.0W Max(NTSC)im guessing that since it says NTSC it should be outputing analog video but i cant get it to work... i know that pin 5 and 6 are power... but ive tried putting the video on the remaining 4 pins and i get no video.im seriously hoping that someone here can help.... i would really hate to have to tell the guy that i cant help him. Thx Quote
trigger Posted June 2, 2006 Report Posted June 2, 2006 Try to give a 75 ohm load as some instrument need a loading.If it still not working, try to pass video signal through a capacitor.Hope this help. Quote
