dark_rebel Posted May 30, 2006 Report Share Posted May 30, 2006 Hey, Im working on a project to adapt a surveillance system. Currently there are 8 cameras going into two monitors. It is an ADT system and the cameras connect to the monitors using rj14 6 pin connectors (ive found that pin 5 is + 9-15 V and pin 6 is ground). The guy wants to keep his existing 8 cameras but switch the 2 monitors for a security DVR which uses BNC video inputs and RCA audio inputs.Ive built a 12V 2 A PS and the power bus for all 8 cameras. But now the tricky part is getting an analog video stream out of the cameras. I thought that they were outputting analog video but i cant get any video onto a regular TV. If ANYONE can provide any useful info i would be VERY greatful. anything from ADT pinout, or what i can do to get an analog video sinal from the camera. Thank you in advanced.PS. . . im at work but i will post the camera model when i get home. That might be useful. Quote Link to comment Share on other sites More sharing options...
dark_rebel Posted May 31, 2006 Author Report Share Posted May 31, 2006 ok... i got the model number.its an ADT A-C4CM/4on the bottom it says 15V DC 3.0W Max(NTSC)im guessing that since it says NTSC it should be outputing analog video but i cant get it to work... i know that pin 5 and 6 are power... but ive tried putting the video on the remaining 4 pins and i get no video.im seriously hoping that someone here can help.... i would really hate to have to tell the guy that i cant help him. Thx Quote Link to comment Share on other sites More sharing options...
dark_rebel Posted May 31, 2006 Author Report Share Posted May 31, 2006 anyone?? Quote Link to comment Share on other sites More sharing options...
trigger Posted June 2, 2006 Report Share Posted June 2, 2006 Try to give a 75 ohm load as some instrument need a loading.If it still not working, try to pass video signal through a capacitor.Hope this help. Quote Link to comment Share on other sites More sharing options...
dark_rebel Posted June 2, 2006 Author Report Share Posted June 2, 2006 Thanks... ill give it a try. Quote Link to comment Share on other sites More sharing options...
