Jump to content
Electronics-Lab.com Community
line in?line out?
only_lonely
For audio signals, line level is between about 100mV to 300mV RMS. Microphone level is 2mV to 20mV and speaker level is a few volts to many volts.
Components like a tuner, CD player or other sound signal circuit use line level to feed an amplifier.
"Line in" is the line level input to an amplifier. "Line out" is the line level output of a component.
Link to comment
Share on other sites
So, if i connect an external speaker at unit A, that port which I plug is "line out" port.
A speaker is supposed to be connected to the output of an audio power amplifier, not a line level output. The line level output can connect to the input of an audio power amplifier.
Then the "line in" port is when i play music at my PC,then i use audio cable to connect my pc to the unit A, to play the sound at that unit A.
Connect the line level output of something to the line level input that you have.
Link to comment
sorry, i am quite confuse now.
OK.
Now i have a UNIT A which has 2 port, one line in port, one line out port (audio jack). Unit A has an internal left and right speaker.
1) If i have an external speaker to test the unit audio functionality,
which port should i connect it?
2) If i have an audio cable now, and i want to play my PC music on the UNIT A's internal speaker,
Link to comment
OK.
Nothing. It doesn't have an output for an external speaker. Connect the line out to the input of an audio amplifier and connect the speaker to the amplifier's output.
Its line input of course.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
