Jump to content
Electronics-Lab.com Community
fm
sssaaa
The transistor's resistors are selected for operation with one supply voltage. If you increase the supply voltage without changing the resistors to compensate for the resulting much higher current then the transistor will get hot and maybe smoke and melt.
The collector of the transistor is connected to the tuning coil and capacitor. Therefore if the antenna is also connected there then anything that comes near the antenna will change the RF frequency. The RF amplifier stage isolates the antenna from the RF oscillator.
Link to comment
Share on other sites
Some simple FM transmitters have the antenna connected to a tap on the coil. Then things getting near the antenna don't affect the tuned frequency as much.
The supply voltage also affects the tuned frequency. In my FM transmitter circuit the oscillator is supplied by a low dropout voltage regulator so its voltage stays the same as the battery runs down.
Link to comment
hi
Are u mean by "things getting near the antenna " my hands, and why when connected to the tap of the coil the osc be more stable
Link to comment
Yes. On FM transmitters that have the oscillator's collector connected to the antenna, your hands or anything metal that gets near the antenna changes the frequency of the oscillator. If you connect the antenna to a tap on the coil then the output power is less and there is less affect on the tuned frequency because only part of the coil is detuned.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
