DIY WBO2
forgot to add that i tried to use the exact parts from eagle but they did not have them all so i used a part that would work on the pcb when i make it, so somethings maybe different, hopefully the part i picked will be the same size as the one i am going to use.  if any parts don't match to the part listed let me know.
and if i post a bmp what dpi should i use??
You do not have to use the exact parts in Eagle as long as the pin out is the same. Otherwise the connections to the IC will all be wrong when you use the original.
If you are going to post a bmp, you do not need a lot of resolution or a big size. If you are not sure, post the bmp and see what it looks like. You can always delete the post and start over.
MP
You attached a very fuzzy bitmap schematic here, but posted a very clear PNG file type over there. Why not attach the very clear PNG to your reply here? Its thumbnail will be resized, but when we click on it then it will be big and clear.
Your car has a +12V battery. In addition to it, your circuit needs a negative supply. Where is the negative supply going to come from?
Sorry, the circuit doesn't need a negative supply, it makes its own.
The power supply for the circuit is very confusing:
1) JP12 I guess is the car's ground but the circuit calls it "-5V".
2) I guess the voltage regulator is a 7810, and the circuit calls its output "+5V" instead of +10V.
3) Pins 1-3 of the LM324 make a psuedo ground for the circuit.
