Shahriar Posted September 10, 2006 Report Share Posted September 10, 2006 HiI want to know If I have an Electromagnet connected to a DC Voltage with a saturated Core, Can I pick up More heavy masses If I increase Current? or because the Core is saturated no difference will be?If I can, Then what is the difference between a Non-Saturated Core with a saturated core in this example...ThanX in advanceShahriar Quote Link to comment Share on other sites More sharing options...
audioguru Posted September 10, 2006 Report Share Posted September 10, 2006 Hi Shahriar,I think that when a magnetic core is saturated then it won't make more magnetism if its coil is fed more current. The extra current is wasted as heat. Quote Link to comment Share on other sites More sharing options...
Shahriar Posted September 11, 2006 Author Report Share Posted September 11, 2006 Thank you Audioguru. ;)Do you know how can I determine the Saturation Current for My electromagnet with i.e. 200 turn 26 gauge wire.I do not have exact information about my core. it is just a piece of Iron.ThanXShahriar Quote Link to comment Share on other sites More sharing options...
ante Posted September 11, 2006 Report Share Posted September 11, 2006 By lowering the temperature of the core and coil you can get some more magnetic power. Quote Link to comment Share on other sites More sharing options...
Shahriar Posted September 11, 2006 Author Report Share Posted September 11, 2006 Dear AnteWould you mind explaining a little more....ThanXShahriar Quote Link to comment Share on other sites More sharing options...
ante Posted September 11, 2006 Report Share Posted September 11, 2006 Hi Shahriar,I don’t know what to explain but if you keep the electromagnet cool of even better super cool then it will be more powerful. Quote Link to comment Share on other sites More sharing options...
Shahriar Posted September 11, 2006 Author Report Share Posted September 11, 2006 Thank you, U explained it :) :)Shahriar Quote Link to comment Share on other sites More sharing options...
