Jump to content
Electronics-Lab.com Community
Posted
Hi guys.
I've been given access to a fully functional Honda CBR 600 motorcyle to mess around with the electronics (just for the record, I'm allowed to break the bike :) ).
While looking through the projects here I found this one in the 'Automotive' section.
http://www.electronics-lab.com/projects/automotive/008/index.html
My question is...Would this work on the above named motorbike?  If not, does anyone know of circuit that would perform the same function?
Thanks in advance peeps :)
Posted
Thanks for your reply. :)
I've just checked the bike and it uses a 12v battery.  Although since my last post we've decided to sell the cbr and use a kawasaki ninja 900 as the test subject instead.  It also uses a 12v batt. :)
Cheers again
  • 1 month later...
Posted
I found a simpler circuit that the guy build and tested.
I think it should work for 12V system as well. Instead of using a darlington, a pnp audio power transistor is used.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
