Jump to content
Electronics-Lab.com Community
LM308 maximum ratings
walid
Hi all my friends
In the datasheets of  Lm308 attached below (at the end) I cut this part for discussion:
and here are the notes:
my questions:
1- What is the differential i/p current, and how to ensure that it will not exceed    10mA?
2- Please explain Note 1, I did not understand it?
Thank you very much.
Link to comment
Share on other sites
Hi Walid,
1) This very old opamp has input transistors with an extremely high current gain.
2) Therefore they have a very low breakdown voltage.
3) So the inputs have back-to-back protection diodes between them to conduct when the differential input voltage exceeds about 0.6V.
4) If the differential input voltage exceeds 1V then a very high current will flow and will burn out the protection diodes unless their current is limited to 10mA.
That is what National Semiconductor says and I just copied it.
Here is a pic that might explain it better:
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
Important Information
We have placed cookies on your device to help make this website better. You can adjust your cookie settings, otherwise we'll assume you're okay to continue.
