maarkr Posted March 5, 2007 Report Share Posted March 5, 2007 http://i50.photobucket.com/albums/f335/Maarkr/switchbox.gifCan I set up a speaker selector switchbox using the ground as the switch to select the speaker pair?? If I run the L&R channels to all speaker outs and use a SPST switch to enable the ground for that speaker, should that work? Is there a way to put some kind of impedance protection in line? Quote Link to comment Share on other sites More sharing options...
audioguru Posted March 5, 2007 Report Share Posted March 5, 2007 You have a stereo amplifier and one wire from each speaker is connected to ground. If you disconnect both speakers from ground with a SPST switch but leave the speaker wires connected together then the speakers will play Left minus Right which is a form of surround sound. The speakers are still a load on the amplifier and they will sound weird when playing Left minus Right.If your amplifier is half-decent then it will limit the current to protect itself when it is overloaded. Quote Link to comment Share on other sites More sharing options...
