salahaldeen Posted April 10, 2007 Report Share Posted April 10, 2007 Hello,Here is a graduation project to have 10 volt input into a buck converter (step down), where the output is connected to the microcontroller through ADC as a feedback, so any variations of output (load change or whatever) than stated by the reference set by the user the microcontroller should adjust it and display output signal and status on a graphic LCD.Anyway, I hope you can suggest a good buck converter design where the microcontroller can control the output through the pulse generated for switching of the converter.Many Thanks Quote Link to comment Share on other sites More sharing options...
ante Posted April 13, 2007 Report Share Posted April 13, 2007 Why would you reinvent the wheel? There are a lot of chips out there with everything built in. All in one chip converters with high stability and no fuzz, why make something more expensive, complicated and less reliable? :-\ Quote Link to comment Share on other sites More sharing options...
