Jump to content
Electronics-Lab.com Community
1.2 V PWm Signal
You don't want a 1.2V PWM signal. The datasheet shows an open-collector transistor that is fed from any current-limited voltage signal. The open-collector is used so that the ADJ pin voltage does not exceed the reference voltage that has a tolerance.
The IC is supplied from a higher voltage that might be able to power the PWM oscillator. If the voltage is 15V or less then I would use a 555 or a Cmos 555 oscillator with two diodes making it do PWM, then it feeds a resistor to the open-collector transistor like this:
Link to comment
Share on other sites
I am currently using LM 324 op amp Ic for generating PWM waveforms from a 9 V supply.Do you mean to say that say taht at the output of the MOSFET I just have to have a 200k resistor and a general purpose BC 547 transistor?
There is no Mosfet.
The 200k resistor is inside the Zetex IC. It is the collector load of the new transistor.
A BC547 transistor is fine.
The output of the LM324 goes up to about 7.8V when the supply is 9V and up to 4.8V when the 9V battery is nearly dead. So the base resistor should be about 100k.
The old LM324 is awfully slow to be used for PWM. Keep the frequency below about 500hz.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
