johno71 0 Posted December 1, 2009 Report Share Posted December 1, 2009 Hello All,I am new to the forum and electronics in general. I have designed some circuits to monitor a 3 phase 230volt electric motor. I am having a problem with the electrical noise spikes generated by the contactor in the motor causing my circuits to act up. I am at a loss for filtering this noise. I have tried a line filter on my power supply and have caps all over the place on the circuit boards. This has helped but has not taken care of all of the noise. Any other suggestions. Thanks,John Quote Link to post Share on other sites
Hero999 5 Posted December 1, 2009 Report Share Posted December 1, 2009 What are you trying to monitor? Quote Link to post Share on other sites
johno71 0 Posted December 1, 2009 Author Report Share Posted December 1, 2009 I have constructed a system to monitor the state of the motor following a given command. ex if motor is supposed to run and dosent the system picks that up and gives the user an indication. Quote Link to post Share on other sites
Hero999 5 Posted December 1, 2009 Report Share Posted December 1, 2009 Care to post a schematic?It sounds like you're having difficulties interfacing the AC circuit with the DC control side.How are you ensuring there's adequate isolation between the AC and DC circuits? Quote Link to post Share on other sites
johno71 0 Posted December 4, 2009 Author Report Share Posted December 4, 2009 Here is a very basic schematic. I have everything grounded, are there any better ways to seperate the a/c and d/cSchematic_for_Noise_Filter.pdf Quote Link to post Share on other sites
johno71 0 Posted December 4, 2009 Author Report Share Posted December 4, 2009 Does anyone know of a lab that i could take my setup to to have the noise analyized near the orlando area?Thanks Quote Link to post Share on other sites
Hero999 5 Posted December 4, 2009 Report Share Posted December 4, 2009 Is the negative rail of the DC power supplies connected to earth?I take it the neutral is earthed?Please provide more information: how do the control boards connect to the motor?Is there any isolation between the AC and DC supplies? Quote Link to post Share on other sites
rakeshkoku 0 Posted February 19, 2010 Report Share Posted February 19, 2010 Is the negative rail of the DC power suppliesconnected to earth? Quote Link to post Share on other sites
ARUN CHOWDARY 0 Posted August 11, 2010 Report Share Posted August 11, 2010 what did you have to monitor in the motor where does noise come inn the motor by applying lubricants only we reduce noise Quote Link to post Share on other sites
