astra Posted January 15, 2010 Report Share Posted January 15, 2010 PLS I MAKING THIS VOLTAGE DOUBLER CIRCUIT AND I WANT ANY BODY TELL ME WHAT IS THE VOLTAGE BETWEEN A&B,A&C,A&D,A&E AND A&F IF THE I/P VOLTAGE 180V A.C ( 30 TO 40KHZ) THANKS Quote Link to comment Share on other sites More sharing options...
audioguru Posted January 15, 2010 Report Share Posted January 15, 2010 Please do not use all capital letters. It is like shouting.Each pair of diodes and capacitors doubles the voltage if the load current is very low. Quote Link to comment Share on other sites More sharing options...
astra Posted January 16, 2010 Author Report Share Posted January 16, 2010 OK about the lettersI know the voltage on every stage is double but on my digital meter I have acrazy results ( the meter working very good) for this purpose I asking. may be have messunderstand if the source voltage=180 v the o/p on the stages =A&B A&C A&D A&E A&F 360 720 1080 1440 1800 V is this right ORA&B A&C A&D A&E A&F360 720 1440 2880 3760 V thanks Quote Link to comment Share on other sites More sharing options...
Hero999 Posted January 16, 2010 Report Share Posted January 16, 2010 What's the meter's maximum voltage rating? Most meters are rated to 2kV and will be ruined if connected to 3760V.Did you measure the input voltage with the meter?What frequency is the meter rated to?A typical multi-meter is only designed to measure low frequency AC, normally 50/60Hz, sometimes 400Hz if you're lucky, not 30/40kHz, if your meter is only designed for 50/60Hz the measurement will be wrong.Is the waveform sinusoidal? If not and you haven't used a true sine wave meter the measurement will be wrong.Check the meter. Quote Link to comment Share on other sites More sharing options...
audioguru Posted January 16, 2010 Report Share Posted January 16, 2010 The 180VAC is 254V peak. If the circuit does not have a load and the capacitors suit the frequency then A-B is 507V, A-C is 760V, A-D is 1013V etc. Quote Link to comment Share on other sites More sharing options...
astra Posted January 16, 2010 Author Report Share Posted January 16, 2010 Hey Hero999Iam not measuring 2or 3kv on the meter Iam just wright anumbers with fixed constant to explan whats inside my mined.. but I measured acrazy results when the I/P voltage =12v A.C Hey audioguruyour explain is clear and near with my results when applied the 12 v sofirst stage = 2 x voltage source 254.5 x 2 = 509second stage = 3 x voltage source 254.5 x 3 = 763.5theard stage=4 x voltage source 254.5 x 4 = 1018thanks for all Quote Link to comment Share on other sites More sharing options...
Hero999 Posted January 16, 2010 Report Share Posted January 16, 2010 The peak voltage is simply doubled each stage minus two diode voltage drops.For 12V should should expect 32.8V, 65.6V and 131.2V.If the capacitors are small then there'll be lots of ripple so the output voltage will be much lower than expected.What are you having difficulty with? Quote Link to comment Share on other sites More sharing options...
astra Posted January 18, 2010 Author Report Share Posted January 18, 2010 thanks herro99but now Ihave tow answers you say first stage x 2 =second stage x 2 = theard stage.......and audioguru sayThe peak voltage x 2 = first stage +The peak voltage =second stage +The peak voltage = theard stage.......so I have abig truble in my mind about this broblemsorry Quote Link to comment Share on other sites More sharing options...
Hero999 Posted January 18, 2010 Report Share Posted January 18, 2010 Why not simulate it?That's what I've done, being to sit down and lazy to figure it out. ;DThe voltage at each point you marked will have ripple super imposed on it so you'll need to add a diode and capacitor, if you want to use them.The voltages are all negative: you need to reverse the polarities of all the diodes, if you want positive.Notes:The input is 5.6V yet, all output voltages are multiples of 5 because you loose a 0.6V in the diodes.All voltages are the peak values, so for 180V the peak voltage is 180√2 = 254.56V. Quote Link to comment Share on other sites More sharing options...
astra Posted February 9, 2010 Author Report Share Posted February 9, 2010 thanks for all and sorry for the late answer Quote Link to comment Share on other sites More sharing options...
