Jump to content
Electronics-Lab.com Community
Posted
5000W is ridiculous for a home-made amplifier. It has no output protection.
It is very dangerous because its speakers are connected directly to the AC line voltage instead of using a normal isolated power supply.
It uses twenty expensive output transistors that might not be available anymore and they will get extremely hot without some kind of high-tech cooling (liquid nitrogen?).
  • 2 weeks later...
Posted
Thanks for the reply.
MJ and MJL are currently available at around R35.00
That transformer can be substituted with an isolation type ( very large ).
The constructor probably fitted thermal cut out switches direct to the heatsink because yes that is very hard work to get rid of that much heat and quite a strenous task for those transisors working into a 2 ohm load :o
I think im gonna skip this one
  • 3 years later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
