stampz2 Posted November 5, 2010 Report Share Posted November 5, 2010 Hi I've been a member of this forum for awhile, but this is my first post, so hopefully it's in the right place. Also, I'm pretty much a newbie at electronics so I might be a little confused at the answer to my questions.and need more help. .I'm trying to do a power supply and I'm wondering if you can can use a 24 v 2 amp transformer for a 25.2 v 2 amp. The urlfor the power supply I want to build is:http://www.play- hookey.coanalog/experiments/plus_5_volt_ps.html]http://www.play- hookey.coanalog/experiments/plus_5_volt_ps.htmlIf I can do the exchange, is there anything else I will need to change?ThanksJim Quote Link to comment Share on other sites More sharing options...
Hero999 Posted November 6, 2010 Report Share Posted November 6, 2010 Yes you could but I think a 24V transformer is oversized.The LM7805 has a maximum voltage rating of 35V but using a 24V transformer, the rectifier voltage when the circuit is unloaded and the mains voltage is on the high side can be above 35V. I'd recommend using a 9V transformer with a 3300 Quote Link to comment Share on other sites More sharing options...
stampz2 Posted November 6, 2010 Author Report Share Posted November 6, 2010 Thanks I'll give it a try.Jim Quote Link to comment Share on other sites More sharing options...
