pyrohaz Posted January 27, 2011 Report Posted January 27, 2011 Hey guys, i've recently designed myself a simple switched capacitor voltage booster, just using the simple 4069 inverter chip. I was wondering though, can you give me any simple information on increasing the efficiency of my switched capacitor booster? I will include a schematic of what mine looks like :)The reason is, im only using a 4 stage booster (2 of the inverters for an oscillator, the rest for voltage boosting.) And im using it to drive my tube preamp :) After I tested it, I got an output of 58v (68k load) and a frequency of 42khz. Now obviously, the calculated voltage should be 60v but im sure the combined voltage drop of 4 diodes is about 2 v (0.6*4=2.4 so actually, a little less)Are there any tips you can give me to improve this circuit?After having a quick look with my multimeter, it said it was only consuming about 7.4mA which actually seems a tad low for a voltage booster IMO. I calculated the efficiency of the current circuit at a mere 55%!Im using 63v Axial 1uF capacitors, they have a blue plastic coating on the outside if that helps :)1N4148 diodes and a PI filter on the output may be a bit of an overkill but its feeding the preamp audio stage so I want as little noise as possible. Quote
Hero999 Posted January 27, 2011 Report Posted January 27, 2011 Using Schottky diodes would reduce the voltage drop to 0.3V per diode.CMOS gates have a high output impedance so you can't expect great efficiency.If you use the 74C14 you can make an oscillator using a single gate and use a fizv stage booster. Quote
pyrohaz Posted January 27, 2011 Author Report Posted January 27, 2011 The 74C14 is the same as the 40106 isn't it? I'm happy with the voltage it is at (the capacitors I have are only rated to 63v, hence why I only used the 4 stages). Would adding another stage not decrease the current I could supply? I was thinking of using one of these switched capacitor boosters in a guitar pedal.For a schottky diode, would the BAT46 be suitable? Afaik, they're rated up to 100v aren't they?Any other tips you can give me?Cheers Quote
