Jump to content
Electronics-Lab.com Community
Heat transfer theory
RyanS
Hi, I'm new to the forum, and I'm a beginner into electronics. I'm trying to design a small fan heater using an 80mm PC fan and a nichrome wire heating element. It will be used as a hand warmer for bad circulation.
I have a similar device which uses a 40mm fan, a commercial product that is very expensive (read: overpriced). but I want to build a second one that is a little larger.  http://www.hmc-products.com/fotos/image/VARIA/Varia/0021-7000a/MANUAL%20USER/0021-8001a-0102a.pdf  its 24V and 33 watts
So far I'm thinking of this design:
- Arduino Duemillnove or Nano (AT Mega328) to generate PWM, and make it PC controllable via USB
- power transistors or MOSFETS to handle the heating element and fan currents
- the 40mm fan uses resistors as the heat source, but I think using nichrome wire would allow more even coverage in front of the face or the 80mm fan.
- 12V as the power source (Arduino is separate and USB powered), because the fan is 12V then I don't need to convert from 24-12V
-it should be able to produce 55 degrees Celcius air temperature, 20mm away from the element
Heres a PDF of the hardware layout:
http://clients.rasvisual.com/temp/80mm_heater.pdf
QUESTIONS:
- is the distance of the nichrome element of 15mm away from the fan at the temperature I require likely to cause any problems for the fan?  although I imagine all heat is directed away from the fan.
- I will have an enclosure around the whole device, with air inlet holes around the top and side of the PCB mounting area. Is this sufficient to draw cool air over the heatsunk transistors to keep them from overheating?
- FINALLY; and in relation to my topic of Heat transfer theory, I'm sure there is a formula to work out the required wattage of heating element to produce the desired temperature at 20mm (55degC), but I'm having trouble locating it or what to search for. Best I can do is that a fan heater is technically a forced convection heat transfer device, I'm looking at laminar flow across the element and forced air has a heat transfer coefficient or btw 10 - 100(W/m2K  I just have no idea how to derive the required wattage.  If anyone is familiar with these formulas I would greatly appreciate their advice. Then I can move on and choose the appropriate transistors, etc.
Link to comment
Share on other sites
The amount of power required is determined by the flow rate and desired temperature rise.
According to Wikipedia, air  has a volumetric heat capacity of 0.00121J/cm3 under standard conditions. This means, if the flow rate is 1cm3/s the amount of power required to raise the temperature by 1oC is 0.00121W or 1.21mW.
http://en.wikipedia.org/wiki/Heat_capacity#Table_of_specific_heat_capacities
You need to know the flow rate of the air from the fan, the minimum room temperature and design a heater which provides a little more power than the minimum power required to heat the air. If you want to regulate the temperature, you need a temperature sensor and some negative feedback in the PWM controller.
To avoid overheating the fan it should ideally be before the heating element, i,e. it should suck cool air in and blow it over the element. There shouldn't be a problem as a typical computer fan should be able to operate up to 60oC anyway.
For safety reasons there should be a thermal fuse and bimetal strip to cut power to the heating element in case the temperature controller fails and the air heats to a dangerous temperature, causing burns and fire.
Have you considered modifying a hair-dryer? It may be the cheapest option but there are obviously more safety hazards: mains voltage and higher power.
Link to comment
Thanks. I'm not sure if I'm applying this formula correctly but using this fan as an example:
http://www.gelidsolutions.com/products/index.php?lid=2&cid=5&id=28&tab=2
Flow rate is 27 CFM == 12,740 cm3/s
minimum room temperature is usually 20C
I want to raise by 35C to get 55C
So 12,740 cm3/s  X  0.00121J/cm3  = 15.4W per 1C  X 35C  = 540 watts!!
so I need 0.27 ohm heating element for 12V. that's not going to work.
The only sensible result I can get is drive the fan at a very low speed for 1000cm3/s to get 42 watts, but I don't even know if you can get the fan that slow. (900 RPM is the specified minimum, but flow rate at that speed, who knows).
I was basically looking only to heat a small area around my computer mouse, at the moment I use a 25 watt halogen lamp which is a pain because bulbs keep  blowing. Ideally I was hoping to design for 40 watts, maximum. similar to the 40mm fan heater I linked in my OP, just 80mm for a wider area.
Link to comment
I think it's worse than that.
1ft = 30.48cm
1ft3 = 30.483 = 28316.85cm3 which works out at around 1.2kW.
This makes sense when you think about it. Look at the power rating of a typical hair dryer and you'll find it's in the region of 1 to 2kW.
A halogen lamp will be more efficient than a fan heater because it only has to heat objects immediately in-front of it, rather than the air which is then used to heat the object. With a radiant heater the air can be at a much lower temperature than the objects being heated, for example on a hot day the air may be 35oC but the road temperature could be 65oC.
Link to comment
Interesting. So the heater I linked must be relying on a really low air flow rate?  http://www.hmc-products.com/fotos/image/VARIA/Varia/0021-7000a/MANUAL%20USER/0021-8001a-0102a.pdf  being a 40mm fan at low speed. I actually have it running at the moment and about 8cm away you can barely feel the flow. it does generate a bit of heat though. Accross the face of the fan are about 6 power resistors.
Could it be possible that low flow combined with power resistors (rather than nichrome wire), allowed them to keep the power consumption as low as 34 watts?
although I can't see whether the source is resistors or resistance wire is going to make a difference. Is one more efficient?
Link to comment
  • 1 month later...
Would a small fluid based radiator plus a low speed fan be more efficient.  Our house growing up was hot water heated and quite efficient.  Also a friend of mine heats his small home with an electric oil filled radiator.  Certainly the wattage for a room heater is around the 900-1500W range, but I would think for the size of this gentleman's application it could be lower.  Though admittedly I've not yet run the numbers.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
