How to switch 3A with a mircoswitch?
There are plenty of MOSFETs which will switch 3A with a gate voltage of 3.7V. The old IRL540 is has an RON of 0.11Ohms at VGS = 4V and ID = 14A. With a source voltage of 3.7V it'll be a bit worse but you only want to switch 3A so it should be fine.
What's the lowest battery voltage? It sounds like you're using L-ion? The trouble is it may not be good enough when the battery voltage is low. Going from the datasheet it appears it should be fine down to 3.5V.
http://www.vishay.com/docs/91300/91300.pdf
Thanks Hero
I noticed that the VGS = 4V. Is that going to be a problem as a fully charged Li-Ion is 4.2v??
Also, how would I connect it to my circuit.
Drain and Source conected in series with my battery and light.
Gate, switched with a latching low current switch, but to Drain or Source? With what size resistor?
Ive found them on Farnell for less than a Pound so these would be great if I can get them to work!
Thank you for answering my questions again
Your "4.2V" battery will be only 3.0V when it needs to be re-charged. The datasheet does not list the voltage lost when the gate-source is only 3V but a graph shows that a "typical" IRL540 Mosfet will have a loss of only 0.2V at 3A. A "minimum" one might have a loss of 1V or more.
Where can you buy a "typical" one?
The old IRL540 will probably do but the VDS may be too high for what you're doing.
Any of the following transistors will be able to switch 3A with 3V.
http://www.onsemi.com/pub_link/Collateral/2SK4043LS-D.PDF
http://www.irf.com/product-info/datasheets/data/irl1104pbf.pdf
http://www.irf.com/product-info/datasheets/data/irl3103pbf.pdf
http://www.irf.com/product-info/datasheets/data/irl2203npbf.pdf
