Jump to content
Electronics-Lab.com Community
Posted
how does a PULSE code MODULATION WORKS?
When I press a button in my IR transmitter it will send binary codes example.
1 1 1 0 with a 38 KHZ carrier.
The IR receiver device will detect the 38 KHZ ( with the filtered code, 1 1 1 0) and will let it pass.
BUT… how does the device know where to put the 1 1 1 0 code? does it have some sort of low pass filter or something ?
http://www.tpub.com/neets/book12/0217.GIF
  • 3 months later...
Guest remonx6
Posted
Sounds very interesting and helpful! Thanks for sharing leonheard.
PCM stands for Pulse Coded Modulation.PCM is uncompressed sound data.Each sample's amplitude is measured and stored as a number. Pulse-code modulation (PCM) is a method used to digitally represent sampled analog signals. It is the standard form of digital audio in computers, Compact Discs, digital telephony and other digital audio applications.
If u need more info watch youtube video on it
www.youtube.com/watch?v=YJmUkNTBa8s‎
If you want to calculated Pulse Coded Modulation or Impedance then use this Engineering Tools. About 38kHz Just now i check it in this online software.
http://actpcb.com/pcb-calculator
If u need more information about PCM email me. Helpful link For New engineers.
Eng Remon
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
