I Really don't understand how in the year 2012 we're able to have the ability to allow a pilot crash a plane.... Why?
I don't get it, there's 3 sensors of almost every critical type (eg, x/y/z gyro info, gps, accelerometer, pressure sensors (barometer) ...
Now combine all these data readings feed them all into a simple unit (infact, could even share the same black box data line from all the sensors)...
Now, the computer really should be able to compensate and have the ability to override the captain...Translate fed data into Altitude, Angle, Speed, etc, and simply have a routine that goes along the lines of this combine that with the onboard sensors to measure how far from the ground you are and there's enough sensors to make sure that even if 3 sensors get knocked out there's almost 3 more ways to get what you need via all the other sensors...
Calculate how long it's going to take to crash based on trajectory.... now it does not really have to say to the captain, you will die in 30 seconds, but it could, instead we have a nicer method....
Time to no Return
TTNR, 30 seconds... Warning Warning, pull up, Level out.
TTNR 20 Seconds, 20 seconds to no return
TTNR 10 seconds.....
at 5 seconds, the software takes over, corrects the angle of flight, pulls it up, adjusts until it's safe enough to return control to the captain, don't confuse this with Auto Pilot, AP can still lead to a crashed plane if the captain stuffs up something...
So at 4 seconds, the captain gets locked out because the captain is obviously an idiot and can't fly a plane.. the result would be an almost un crashable plane, and as an added bonus, it would also prevent terrorists from crashing planes into buildings, the plane would simply not allow it.... pretty much like a car that can't crash..
now, just incase worst case the software screws up, the captain can be trained to override it via a switch that's protected to re-gain control, but id much have this button hidden away, eg you don't really want a terrorist doing it... or some kind of key code to override it which i guess would put the captain at risk...
how about a small explosive charge to destroy the button/switch or pop out for the captain to destroy to prevent a terrorist crashing a plane...
What do people think to this idea?
Time to no Return
