Seriously? I based that schematic and plots on your posted schematic, not additional loads. That power supply is being milked with that circuit alone. If you have additional current sucking circuitry, all bets are off !
Yes, good.So lets ignore the hows and whys about the IC etc and assume that as long as the correct current is flowing through the second zener/resistor leg (the 8.2v one) and that the zener is not overloaded by increasing the first zener, I'll be good.
The behaviour of the power input circuit is determined by a combination of factors. The mains voltage and frequency can't be changed. Other factors are the input coupling capacitor (the 1 uF one), the zener voltage, the smoothing capacitance, and the load current.A) I'm going to replace the relay with a new 24v one.
B) I'll increase the zener which will also mean increasing the resistor in series with the second zener and checking the wattage of the first zener remembering it's only half wave. I am just unsure how much to increase it by or how much to increase the 1u cap by.
Can you connect two zeners in series?My sim does not have zeners over 25v sadly so I can't do it myself *sigh* otherwise that would be easy![]()
Thanks Steve.
Regarding the bridge rectifier idea, I suggested that earlier, and CDRIVE disagreed, because the negative rail of the circuit would no longer be at ground potential, which it currently is <snip> I'm tending to agree with CDRIVE that it would be better to leave the circuitry common rail connected to Neutral, rather than have it jump between 0V and -30V relative to Neutral during each mains cycle.
Thanks for your input.
Actually I was suggesting putting the bridge between the feed capacitor and the zener. Since the feed capacitor would be in the Phase side, and the combination of the bridge and the zener would limit the voltage across the bridge to 30V, the ground rail of the circuit would only jump between 0V and -30V relative to Neutral, but neither of us realised that at the time, which is why I didn't query your "338V peak" claim at the time.Actually, I thought you were referring to connecting a bridge directly to the mains prior to the zener. This would have dictated lifting circuit common off mains neutral and would have placed common 338VP above mains neutral.
Yes, another case of too little information. I imagine it's a compact sealed unit and there wouldn't be room.Bassmo has never completely explained the physical layout of this pump/control. I've repeatedly asked why a dirt cheap wallwart couldn't replace this power supply section. The power demands of the control is very low. Just about any 24V wallwart could replace it.
Not a good idea, there will be slight differences between zeners (even from the same batch) that will cause one to take the majority of the current. You CAN put two or more zeners in SERIES, though.Can one put 2 equal value 1W zeners in parallel to allow 2W dissipation?
That shouldn't be a problem. The peak and trough voltages are both well within the minimum pull-in voltage and the maximum allowable voltage.I also just noticed there's a 2.1v p-p ripple on the relay too. is that too much for a 24v DC relay? The one below to be precice![]()
The principle is sound, as I said many times, but the component values are clearly not appropriate for that amount of load (about 20 mA with the relay open and 40 mA with the relay closed). No surprise at all that the original relay contacts burned out. I wonder whether the company makes any component value changes when they "fix" the returned units.I can't see how this circuit ever worked - yet it did albiet it's failed before and the company charges $400 to have it replaced. What a joke! It must have been pushing the absolute limits and no wonder the relay burned it's contacts out. It's ridiculous really underpowering a relay for such heavy switching loads.
That relay sounds perfect.FINDER - 40.61.7.024.0000 - RELAY, PCB, SPCO, 24VDC [...]
I can't find any posts from you that show the effect of varying the input capacitor. The ones I can find relate to changing the smoothing capacitor, C2.Perhaps it's been long forgotten but I posted a number of schematics, simulations and plots that clearly showed the results of modifying said components. Currently, this part of the thread is a re-hash of what's already been covered waaay back.
