Mouse-trak (trackball)
HellasTechn
Apr 14, 2013
1,579
Dear friends Good day.
I have a mouse-trak b-9pind (trackball) this is a mouse that is mainly used on servers or other control systems.
The specific model (b-9pind) has an rs232 DB9 connector.
The thing is that someone thought that this was useless and cut the cable and took the connector.
My problem now is that i have no idea how to connect the wires on the new connector.
The PCB has a 10 pin header connector
Any idea what to do ? Mabe someone somewhere has the same mouse and could measure the cable and tell me ?
Here is a diagram i found online :
http://www.chameleon-group.com/itac/spec_b9pind.htm
And this thing costs a couple of hundred dollars to buy new !!!
Elecbegginner
Mar 24, 2013
103
can you open the unit and see if there is pins names on the electronic card ?
you can rewire easily after that
in your case pins 1 & 9 are not used
here is the db9 diagram :
HellasTechn
Apr 14, 2013
1,579
Yes this is the typical rs232 pinout diagram but on the PCB there are no numbers on the pins and there is no way that i know of to identify them...
Plus that on the connector there are 10 wires (one of them is tha chassis ground) The connector on the PCB is a 10 pin header connector
Elecbegginner
Mar 24, 2013
103
Normally on the electronic card where the pins wires are soldered you can check if there is some writing near the solder pads ( they could be underneath ) , that way you can recognize every pin's specific solder pad on the card & rewire .
Alternatively, you may find that the pins are driven from an IC. You may be able to locate the specs and from this determine a likely mapping.
Do you have another similar mouse?
HellasTechn
Apr 14, 2013
1,579
No luck... nothing is written
That is not that simple because jumpers are also involved and there are a couple of ic's...
This is going to be a hard one to repair ! If i ever make it !
Got any photos?
HellasTechn
Apr 14, 2013
1,579
Not at this time...
I have tried a few combinations but no luck so far.
I have to consider getting a new one.
