HIGH-VOLTAGE POWER SUPPLY-CIRCUIT THEORY
HIGH-VOLTAGE OSCILLATOR. The high-voltage power supply consists of an oscillator (Q1) and a rectifying circuit. When the instrument is turned on +15 volts unregulated is applied to Q1, turning it on. As Ql conducts through the primary winding of A15TI (pins 3 and 4), positive feedback to the base of Q1 occurs through another winding of the transformer (pins 1 and 2). When conduction through Ql reaches saturation, the magnetic field developed in primary winding (pins 3 and 4) starts to collapse. This induces reverse feed back in the other winding, causing reduced conduction through Q1. With varying conduction through QI, the circuit oscillates at a rate determined by the inherent distributed inductance and capacitance of the oscillator circuit. The magnitude of the .oscillations, and consequently the output of the power supply, is controlled by the voltage at the output of differential amplifier Al5Ul.
HIGH VOLTAGE REGULATOR. A reference voltage from the +15-volt supply is established at the junction of A15Rl3 and A15R37_ The voltage is applied to a differential input on amplifier A15U1 through AI6R23. A sample of the cathode voltage for the CRT is also applied at the junction of A15R23 and A15R37 through A15Rl31 A15C8. Any change in the cathode voltage is amplified by A15U1 and applied through the primary winding on A15Tl to the base of high voltage oscillator Ql, changing the amplitude of its oscillation. The change is in such a direction as to correct the original change in the rectified cathode voltage. Diodes A15CR1 / A15CR2 protect the oscillator transistor from excess reverse voltage.
HV DISABLE. Transistor A15Q2 monitors the +120 V supply through resistor network A15R41 and A15R31. If the output of the +120 V supply drops below approximately +100 volts, A15Q2 conducts, turning on A15Q1. With A15Q1 conducting, a ground is applied to the base of high-voltage oscillator QI, cutting it off. In addition, if the +120 V supply surges above approximately +138 volts, zener diode A15VR5 conducts, turning on A15Ql. Again the high-voltage oscillator turns off. This protects the CRT from high- intensity bums. DEEP ERASE switch A15S1, when engaged, disables the high-voltage oscillator and gate circuitry to the CRT. The switch is engaged when deep erasure is required to remove deeply written images from the storage mesh. In the event that the -15 V supply is shorted to ground, A15Q2 turns on, turning off A15Ql, protecting the CRT from high intensity bums. Shorting the +15 V supply to ground causes the output of A15U1 to go low, turning off A15Ql, again protecting the CRT. A protection circuit consisting of A15Q4 / A15U21 / A15Q5 is incorporated in the cathode circuit to prevent accidental burning of the CRT during deep erase operations, while turning the instrument on and off, and during quick power dropouts.
When the instrument is turned off or the DEEP ERASE switch is engaged, A15C18 discharges, turning off A15Q4. When the instrument is turned on or the DEEP ERASE switch is returned to its NORMAL position, A15CIB starts charging towards the -15 volt supply through A15R44. Until A15CIB becomes fully charged, A15Q4 is cut off and there is no current flow through A15R45. A15U2. is an opto-electrical device consisting of an LED and a light-sensitive transistor. With no current flowing through A15R45, the LED is non-conducting and the light sensitive transistor is turned off. This turns off A15Q5 and the CRT cathode is now 100 volts positive with respect to the grid by AI5VR3. This action disables the write gun in the CRT.
The time that it takes A15C18 to charge to -15 volts allows the high-voltage regulator circuit to stabilize the output from the high-voltage oscillator. When A15C18 becomes fully charged, A15Q4 conducts causing the LED in A15U2 to turn on. This turns on the light-sensitive transistor, turning on A15Q5, effectively bypassing A15VR3. This action enables the write gun of the CRT.
HIGH VOLTAGE RECTIFIER. The CRT cathode and grid 'voltages are developed in the secondary of high voltage transformer A15T1. The cathode voltage is rectified by A15CR3 and filtered by network A15C6 / A15R11 / A15C7 before application to the CRT. The rectified cathode voltage is also used as. a reference level for the CRT filament voltage (developed on a separate secondary winding on A15T1), the grid bias voltage, and focus voltage. The cathode voltage is adjusted to -2295 V by HV ADJ potentiometer A15R38.
The CRT grid voltage is picked off the secondary winding of transformer A15Tl at pin 5. The voltage is applied through an RC network (A15C21 A15R3) to diodes that clamp the voltage swing between that established by intensity limit control A15R2 and the gate de levels. The peak-to-peak voltage swing is rectified and applied to the CRT grid which is voltage- referenced to the cathode. This controls the brightness of the CRT trace.
The HV Multiplier voltage is picked off the secondary winding of transformer A15T1 at pin 7. The voltage is applied to HV Multiplier Assembly A6 where it is multiplied (X3) and then applied to the post accelerator of the CRT. The post accelerator voltage is approximately +5 kV.
