Okay, so I'm a bit confused about how resistors work.
I understand they increase the resistance of circuit an all, but look at this example:
We have a circuit that's resistance is 0.003Ω and a power supply of 1kW, based on ohms law we can calculate the Voltage: 1.73V so the current flowing would be: 576.6A.
So, if we would like to increase the applied voltage to a certain component in that circuit, we can increase the resistance correct?
What if the resistance across that component is the same at 0.003 Ω ,and the voltage would be the same at 1.73V, even when adding a resistor to try and increase it?
Side question: Are there resistors that can handle massive amount of dissipate power? I mean, in kW or MW of power?
I was thinking about kW or MW of power converting massive current into higher voltages or vice verse, that requires a unique resistor right? And can a resistor be designed to increase resistance by a few mili-ohms and dissipate a lot of power?
