I have just assembled 3 * IR2110 Hi/Lo Side Drivers onto a PCB I mocked up to do some BLDC motor tests...for the High-Side Floating Supply I have 1 * 0.1uF Ceramic, 5 * 4.7uF Ceramic and 1 * 68uF electrolytic (obviously in parallel)...I realize 6 Ceramic Caps are over kill but I wanted to make certain there was plenty of reserve for low frequency testing.....theoretically the combination should result in roughly 92uF; however, the 4.7uF ceramics actually measure between 5.5uF and 6.2uF while the electrolytic capacitors were all between 72uF and 73uF ...anyway the total capacitance in one half-bridge measures 106uF, the second measures 104uF and the third measures 99uF. I understand larger capacitors (especially electrolytic capacitors) have a wide tolerance range, and can be expected to lose capacitance over time....is there any good reason to attempt to "balance" the three 1/2 bridges any closer than the ~7% they currently are? My instinct tells me, "no", but I have had trouble in the past with high-side mosfet drivers, and I just want to make sure I am not making invalid assumptions....
This is the circuit I used as a guide.....
(The above is a screen-shot copied from Figure 5 here: http://tahmidmc.blogspot.com/2013/01/using-high-low-side-driver-ir2110-with.html )
On this board I currently have IRF640 Mosfets (he does not specify any particular devices for Q1/Q2), I used MUR1100's instead of the UF4007's, but the specifications are indistinguishable, and I had the MUR1100's on hand. For C3 I used 3 * 68uF 35V electrolytic capacitors (one for each 1/2 bridge.....same type capacitors I used in the High-Side Floating supply). So, other than having 6 Ceramic Capacitors on the High-Side Floating Supply my PCB is almost exactly as he has it drawn....Just want to make certain "balancing the capacitance" closer than ~7% is trivial...
So, any thoughts before I power it up?
Fish
Fish
