- Joined
- Nov 28, 2011
- Messages
- 8,393
1. Corrections as marked to bridge rectifier connections
2. Suggest not using "humps" to indicate crossing wires with no connection
3. You sneaked in a substitution - Q1 from TIP29B/C to TIP31C. That's fine.
4. That image is barely readable, and it's in JPG format, which is designed for continuous-tone images (photographs, basically). You should use GIF or PNG for line drawings. This will make them cleaner and smaller size than JPG. (Not in the case of the image in this post, because I was working from a JPG file.)
