- Joined
- Dec 18, 2013
- Messages
- 5,178
Fair enough, I still have to shoehorn it in to the box!So either 16ga or 14ga are acceptable, 14 obviously better than 16.
I was reading about tinned multi-strand conductor wire and thought it would be a good idea until I read that tin only has 15% the conductivity of bare copper. Being humid and hot down here, I wondered how quickly I could count on that bare wire keeping in said condition... Lots of variables in design!
Your thoughts on use of tinned wire vs. bare copper? Anyone feel free to chime in as well!
I think Kris has covered this well. I have done a bit on mains and LVD (low voltage directive). In the UK you need to make sure the wire has the correct current rating for the length you are using to prevent excessive heating and voltage drop.
The fuse needs to be rated with respect to the current handling of the wire to protect it from over heating also. It is also permissible if the wire is less than 1 meter long for you to use a smaller gauge wire even if the wire spec is for a lower current. I'll try and dig out the info for this.
Clearance and creep-age gaps also need to be considered, this depends on the type of equipment being designed. Here is a chart that may help.
If you have mains wires soldered to the PCB you also have to have them supported so if they break they stay together. The way we did this which is a really easy fix was to cable tie them together and we passed the test. This is classed as adequate support??
With regard to tinned wires and connectors. I was always told, screw type connector (which uses an actual screw, UK plug as an example) should always bite down on a solid wire or ferrule. I guess tinned would come under this?. And bare multi-strand for the lever clamp type screw terminals. And yes I know nobody does this but I think they should.
Don't know if this is of any help or relevant.
Adam
