- Joined
- Dec 18, 2013
- Messages
- 5,178
Hi John
Using 70um copper (2oz) with no plating I get 2.7 Amps will blow the trace in 5 seconds. So if you had a 3 Amp fuse fitted and a fault developed that drew just under 3 Amps as an example the fuse wouldn't blow but your track would. This uses Onderdonk's equation.
Is your base copper 2oz with 1oz plating? or 1oz base and 1oz plate to give you overall 2oz?
Thanks
Adam
Thanks
Adam
