- Joined
- Dec 18, 2013
- Messages
- 5,178
I don't know quite enough details to determine if and how the cross section area of the coil will affect the output...
Of course, you could try making a couple of sample coils to find out:
Take the plastic casing from a Pen and wrap the wire around that as an example, then try the same thing with the casing from a marker or highlighter.
Cheap components. Will cost you wire, and maybe a few cents for the pen/marker.
Here's where it gets tricky though... the same number of turns in a smaller coil will have a different inductance and length of wire than the larger diameter... again, I'm not quite familiar enough to determine exactly how this will affect performance. I know about enough to know that more turns will provide a higher voltage output, and that the coils should be wired in parallel if you were to use the arrangement in the second image on post #27.
Perhaps someone has a formula or some example math to help determine the characteristics of the coils and how they will generate electricity.
Its all about number of turns and surface area.
Adam
