Missing Varistor on Coleman Powermate generator
poppacorn
May 14, 2016
3
Hello friendly folks, I could use a bit of help please.
I have a Coleman Powermate 5000 model# PC0525302.04
The power died while under load (10hp Tecumseh gas motor kept running fine).
Removed the alternator end bell and found that one of the three varistors is missing from the AVR circuit board.
The two remaining are 431kd10 & 10d621k.
Not sure what's missing, can't find a schematic anywhere.
Here is the whole board for sale, but I just want to know what the missing component is:
http://www.partsfortechs.com/asapca...oltage-regulator-replaces-0062479-p-1088.html
Photo of my damaged board attached.
Is it ok to just jump this with a copper wire for a quick fix to get the power flowing again?
Anyone have a similar AVR board or schematic that they can check and tell me the missing component? (Powermate AVR 0065649)
Thanks very much!
Alec_t
Jul 7, 2015
3,821
That electrolytic capacitor bottom left of the pic looks bulged and leaky? If so it could be the cause of the failure.
Not if it's connected across the power rails!:eek:. Can you be sure the 'missing' varistor was ever there?
poppacorn
May 14, 2016
3
Thank you for your reply.
Comparing mine to the online parts image, it looks like there's supposed to be a third varistor there.
Also the remnants of the two copper leads are visible in the torn epoxy coating.
Does it have to be replaced by an identical varistor or will any varistor rating suffice? Maybe I can pull one off another board laying around and give it a try.
Thanks!
Alec_t
Jul 7, 2015
3,821
Has someone already had a tinker with the board?
Definitely NOT.
If you look at the datasheets for the two varistors you will see that their continuous withstand voltages both exceed your power supply voltage, but differ from each other. I don't know why that is; perhaps a belt-and-braces approach to suppress transients, offering two levels of defence? If you do add a third varistor I'd suggest one with a voltage rating matching either existing one, but perhaps with a slightly higher dissipation (Joules) rating.
poppacorn
May 14, 2016
3
Hello, thanks again for your reply.
Yes, a burnt circuit on a different area of the board itself was re-soldered just a few days before the varistor disappeared. Maybe it was compromised in the process and then broke off under vibration.
Definitely NOT.
OK, thank you very much.
