Hi all,
i have attached the following circuit. it is basically a opamp driving a n channel fet used as a constant current source.
the drain of the fet is connected to 0V, the source is at -5v. the gate is driven from the opamp output via 100R.
my understanding that the opamp will drive the fet into conduction, this switches the current through the fet which develops a voltage drop across the 1M resistor. This keeps both of the inputs of the opamp terminals at the same voltage (minus the opamp input offset voltage). hence the current output is given by I = Vin / 1M. the ciruit reaches equilibrium when enough opamp output voltage is generated to control the fet to allow exactly the current to flow through the 1M to create a voltage drop equal to vin.
Am i correct in saying that if Vin is -0.5V, the opamp output is driven positive ie. towards 0V?
My other question is what equations satisfy the fet control i.e. is it in linear mode? saturation mode? could someone help with this part of the circuit. could someone explain with equations what is happeining with the fet.
Thanks in advance,
Raj
Thanks in advance,
Raj
