I've retrofitted some G4 LED bulbs in to some pond lights, but they're so much larger than the halogen G4s that they replaced. They can't fully fit within the reflector mount, as the diameter of the bulb base is larger than the hole.
I've managed to disassemble the enclosure and remove the reflector mount, so if I can enlarge the hole then the new bulbs will fit just fine. Here's a photo of a similar reflector (not the same, but almost identical):
As I can't get replacements, I've only got one shot at this - so I thought I'd pick your brains before I try enlarging that hole. I'm not sure what the material is, but it's delicate I imagine.
Any thoughts on how you would approach this? I imagine that drilling it out won't end well. My current thoughts were to use a conical metal file and see how that goes.
