Enlarging hole in reflector?
Ian
Administrator
Aug 23, 2006
1,486
I've retrofitted some G4 LED bulbs in to some pond lights, but they're so much larger than the halogen G4s that they replaced. They can't fully fit within the reflector mount, as the diameter of the bulb base is larger than the hole.
I've managed to disassemble the enclosure and remove the reflector mount, so if I can enlarge the hole then the new bulbs will fit just fine. Here's a photo of a similar reflector (not the same, but almost identical):
As I can't get replacements, I've only got one shot at this - so I thought I'd pick your brains before I try enlarging that hole. I'm not sure what the material is, but it's delicate I imagine.
Any thoughts on how you would approach this? I imagine that drilling it out won't end well. My current thoughts were to use a conical metal file and see how that goes.
14,306
Probably metallizes plastic?
Do you have access to a mill? Removing material from the 'top' of the cone (the smaller end) will automatically enlarge the hole. A fast bit on th emill should work through plastic without breaking it Ideally you add cooling.
Ian
Administrator
Aug 23, 2006
1,486
Many thanks for the ideas!
Yep, it looks like a metalized plastic.
No mill access, unfortunately - just a pillar drill, router table and most hand/power tools.
Try sanding it down on a belt sander ? Of course if you do have access to one.
No belt sander either, but I've been considering buying one for a while, so can get one if needs be (I've got about 5 assorted power tool sanders though :confused:).
I'll do a quick test and see how how easily the material responds to sanding and/or filing.
Arouse1973
Adam
Dec 18, 2013
5,178
You could try a Dremel with a thin saw blade maybe?
Adam
Ian
Administrator
Aug 23, 2006
1,486
Wrap some tape around the light just below where you want to cut. That will help hold it all together.
Adam
Good idea, I hadn't thought about that!
I've taped it up and used a flat file to bring the level down (similar to how Harald suggested), rather than trying to open it up with a round file. Seems to be working so far, although I need to wait until it's light outside to test it in the pond :).
Many thanks for all the suggestions :).
dave9
Mar 5, 2017
1,191
Since you have no belt sander, mark a line showing what to remove and do it manually with a piece of sandpaper taped to something flat like a piece of glass or a counter top checked with a straightedge. Rinse (not wipe) any stray abrasive particles away so you don't scratch the reflective surface.
  • Like
Reactions: Ian
kellys_eye
Jun 25, 2010
6,512
Isn't the reflector designed to have a 'focal point' that you're effectively moving by removing plastic? With a new bulb improperly positioned you won't get the designed beam pattern/width whatever....
dave9
Mar 5, 2017
1,191
^ That is true with incandescents (having a spot point of filament light) designed for throw, but to a lesser extent with LED retrofits and flood beam reflectors. The design of the LED bulb often swamps the rest and the more sideways oriented LEDs there are, the more disfigured and floody the beam compared to the original.
In other words if the desired effect is exactly illuminating one thing and only that thing, it could take several attempts with different LED bulbs to (re-)achieve the desired effect, odds being that the closest beam would come from a deeper recessed spot-point from a single higher power LED rather than a Christmas-tree style bulb with rows up and down the bulb assembly.
Ian
Administrator
Aug 23, 2006
1,486
The light source is considerably further forward in the reflector too, due to the huge difference in size between the halogen and LED G4 bulbs - so I think the focal point will be quite off. I'm not too worried about the drop in reflector performance, as it's more for stability and aesthetics that I need to add the reflector back in. As long as there is light generated within the pond, that's good enough for this case :).
FuZZ1L0G1C
Mar 25, 2014
366
Enlarging:
I'm thinking of something along the lines of the steel-conduit reamer bit for enlarging the ID.
The actual reamer bit is probably too angled, which would make the mounting unstable.
Another idea would be to get hold of a narrow taper cone, such as on a PVC ground-spike which my solar panel assembly uses (2 cm pipe diameter tapers over about 15 cm).
With suitable sandpaper wrapped around, could be rotated to gradually widen hole.
Focusing:
Maybe a Paxolin PCB threaded and fitted with small machine screws?
Saw a similar 'screw-type' focuser this evening, on a website re constructing a Dobsonian Reflector.
Ian
Administrator
Aug 23, 2006
1,486
Thanks for all the advice everyone - the job is done and it works a treat :D.
