Retrofitting a vintage radio for blue-tooth playback. Power problems.
cyberpagan
Mar 27, 2018
3
Ok. So I have been trying to retrofit a blue-tooth module into an old transistor radio to turn it into a portable blue-tooth speaker.
So far I have managed to get the blue-tooth module working with the radio and playing audio out of the speaker but I have run in to a problem that has me stumped.
The radio runs off 6V and the blue-tooth module can also operate at 6V. Both the radio and the module work fine when separately connected to a power source or a battery but when I wire them to the power source together in parallel neither work. the blue-tooth module even heated up and smoked a little when left wired up for to long.
Both the radio and bluetooth module work fine together when wired to separate power sources.
So is there a way to have both the radio and blue-tooth module powered from the same 6v power source with out interfering with each other?
The model of the radio is: PHILIPS L3Z73T https://images.ehive.com/accounts/3031/objects/images/1rppl9_cnme_l.jpg
The blue-tooth module is: http://vi.raptor.ebaydesc.com/ws/eB...ategory=44999&pm=1&ds=0&t=1512958894000&ver=0
duke37
Jan 9, 2011
5,364
Unstabilised 6V supply could easily be putting out 9V, hence the smoke!
The polarity of the power supply is critical.
I would link the two devices through capacitors to eliminate DC shorts
cyberpagan
Mar 27, 2018
3
Where should the capacitors go in the circuit? what type of capacitor?
Thank you so much for the reply.
cyberpagan
Mar 27, 2018
3
What power sources? Specifics?
There is a power supply transformer inside the radio that puts out 6V. My intention is to run it off a 6V battery i pulled from an old mobility scooter. All parts work when separately wired to either power supply or battery but then cease to work when wired together.
kellys_eye
Jun 25, 2010
6,512
The bluetooth module will work from 5V plus or minus 5% so it's unlikely the transformer supply will be able to give such an accurately regulated output for that module - hence the smoke.....
Using a 6V battery would allow you to use a simple silicon diode as a series 'dropper' (it will reduce the 6V to 5.3V) which would be acceptable.
Have you 'commoned' both the negative supply wires? i.e. the black wires (assuming black/red are neg/pos) of both the radio and the bluetooth are joined?
