I have a 4070B I.C. Chip, along with a breadboard, that is a quad 2-input chip and It was working fine when I first got it. Ground was hooked up to it and all the inputs affected the output. Now what is happening is only the right side of it works and the left side inputs all go directly to ground for some reason. I put a resistor on ground that was about 21k ohms and that was when it was somewhat functional which wasnt needed when I first used it. Is there something that I may have been doing wrong?
Also, I’ve used the chip for a while, using it multiple times in adders and pulling it in and out of the breadboard, which was a softer pull so I didn’t ruin it if I could.
