Transistor in a Halloween Prop
scorn001
Oct 19, 2018
4
I'm looking for a replacement to a transistor in an old Halloween prop I'm in the process of repairing.
On the part itself, I'm seeing "HSB772", however Googling that seems to lead me to a TO-126L package part. This one looks like a TO-92, which I think would a "HSB772S" possibly.
I've found data sheets for the part, but that's about as far as I can get. I'm unable to find a location to purchase that part, and I'm unable to find an available replacement - and being a software guy - I really don't have the expertise.
Hoping someone else will have a little more knowledge than I.
Pic of the component in question is attached.
Any help would be appreciated.
kellys_eye
Jun 25, 2010
6,512
It's probably a 2SB772 given the way those numbering system go and the datasheet I found for that one seems correct too.
The device has blown quite spectacularly indicating other issues apart from the destroyed device - can you post a wider picture of the area?
73's de Edd
Aug 21, 2015
3,730
Sir scorn001 . . . . .
Q21 assignment tells us that this little puppy must be absolutely stuffed with other transistors. ( Circa '80's vintage construction)
The nearby TIP ??? power transistor might be a like candidate for having crashed and dumped into this unit in case this unit is being its driver.
73's de Edd
scorn001
Oct 19, 2018
4
This device drives a motor that opens a set of curtains in the front, revealing the "All Seeing Zultan!". That part had failed previously, and my children desperately wanted to see and play with in. So I physically fixed the curtains open with some wire. When that motor failed, and then the repeated use caused the failure is my guess. A smart person would have unplugged the motor connector :).
That motor did test bad, it's possible there are other failure points though.
I've attached more photos.
scorn001
Oct 19, 2018
4
73's de Edd
This thing was actually marketed and sold back 2006-2007 I believe. I'm thinking the failure of the motor this part was driving was possibly the cause of the failure?
Thank you.
kellys_eye
Jun 25, 2010
6,512
Yup, I'd go with testing/replacing the larger transistor that drives the motor too.
kellys_eye
Jun 25, 2010
6,512
In what way 'bad' - a motor will test as good as a 'short-circuit' under even normal measuring techniques.
Just apply power to the motor directly (battery?) and see if it does as it should.
scorn001
Oct 19, 2018
4
Yes, sorry I should have been more clear. I applied power with a bench supply - no workie.
