Hello,
What voltage did you get on pin 20?
Is it about the supply voltage?
It can be there is a pull-up resistor inside the unit.
Bertus
I got around 10V on pin 20. It's not the same as supply voltage as supply is 12V to 13V. When I measure voltage on pin 19 which is supposed to be speed signal output, I get a much lower voltage reading I cant remember exactly how much i think it was something like 3 or 4 volts. If i connect a LED to pin 19 it gets a very litte bit of power and u can just about see a little bit of the LED. But on pin 20 the LED powers up fully. The LED i'm testing with has a inline resistor built in to be able to handle 12v
