How to Convert uT to w/m2
Status
Not open for further replies.
epsolutions
Sep 7, 2019
116
Is there any way to make a mathematical conversion between watts per square meter to Teslas?
For example, if a 10mW/m2 RF signal was measured at a given surface, how can the magnetic component of the signal be quantified in micro Teslas?
davenn
14,484
not that I'm aware of as they are 2 totally different things
one is an EM field strength, the other is a magnetic field
Edit
looks like I may stand corrected ……..
uT = W/m2 / 239 (Micro-Teslas = Watts per square metre divided by 239)
nT = W/m2 / 239,000 (Nano-Teslas = Watts per square metre divided by 239,000)
epsolutions
Sep 7, 2019
116
I now recall seeing that 239 figure before. It is reflected in the attached chart where 960 W/m2 equals 1.0167 uT
But, as you say, a static magnetic field and an EM signal per surface area are two different phenomena. However, they seem to be subject to correlation somehow. Possibly because EMR has a magnetic vector that can be quantified?
However, I do not understand the "real life" significance.
Can someone please explain according to what physical laws can a force (magnetism) and a different force (EMR) per surface area at an unspecified frequency be equated? I have researched extensively online and can find no definitive answer.
  • Conversion_Chart_dbm_v_m.pdf
epsolutions
Sep 7, 2019
116
I believe frequency and wave form are related to signal density. That aside, what about the rest of my question?
Status
