- Joined
- Nov 17, 2011
- Messages
- 14,271
No, the reference voltage is a fixed value.Expect 1.23 V.
The meter indicates OL - overload. Does that happen when you short-ciruit the inputs (volt/ohm vs. common), too?
Check U1, pin #37, labeled VRH, for the presence of the correct reference voltage (1.23 V, see datasheet).
Solder two wito have any access to it i need to flip the board which won't allow me to have the key to turn the multi-meter on,
You need to learn how to read a schematic diagram. There is a 9 Ω resistor in parallel to D5 and D6 which is what you measure as a short circuit. Measuring components while inD5, D6 i put in yellow rectangle are shorted but it's not the diode it's on the circuit,
The manual I looked up states "overload".OL on the meter refers to Open Loop, not overload.
ok i'll solid one to R15 the side that is connected to pin , and where to solid the other one?Solder two wi
i'm trying to learn, still beginnerYou need to learn how to read a schematic diagram.
You measure between the Vref pin of U1 and ground (0 V).ok i'll solid one to R15 the side that is connected to pin , and where to solid the other one?
I've (I think) never before seen a multimeter display "open loop". It would have to indicate "OL" any time no quantity to be measured is connected to the input. Meaningful in the resistance measurement position only. In the volts or amps range the display shows 0.000 (+. a few digits), not "OL".This is what comes from Chinglish translations.
ok the Vref is pin 38 not 37 i checked on the pcb, and it have a check point on the back of the pcbYou measure between the Vref pin of U1 and ground (0 V).
According to the datasheet, pge 3 Vref = Pin 37 - that is the output where a stable reference voltage of 1.23 V should be measured.ok the Vref is pin 38 not 37 i checked on the pcb,
those are the measurementsAccording to the datasheet, pge 3 Vref = Pin 37 - that is the output where a stable reference voltage of 1.23 V should be measured.
That looks good.pin 37, com = 1.2
to the com port not the VB- of the battery right?measured vs. gnd/common
what do you mean with input terminal of the pcb shorted?Measure with the input terminals of the pcb shorted to avoid noise from open inputs
yesto the com port not the VB- of the battery right?
the measurement sockets where your banana plugs normally go.what do you mean with input terminal of the pcb shorted?
R6 is connected to pin 20 which is OVH. Acc. to the datasheet OVH is an output for resistance measurement. Seeing 3 V here doesn't seem to be unusual.
Sorry, I should have excluded that pin from the range of pins to be measured in my post #32.
What about the other pins I asked you to measure ? It intrigues me that from these pins you managed to pick just the one that is an output![]()
No, the schematic is a representation of the actual pin layout of the chip. But yes, the pins are small. You don't have to solder the wires to the chips's pins. find the component the pin is connected to and attach the wire there, if that is eaasier.also trying to find those pins on the mcu, on schematic is different than in real and the pins are really small
