roughshawd
- Jul 13, 2020
- 616
- Joined
- Jul 13, 2020
- Messages
- 616
I asm fixing the old radio antenna off a boat.
The old antenna cable broke off at the mount, its a screw in antenna,fiberglass.
But it is so decomposing, I think I will put a new coat of fiberglass resin over it to rebuild the covering on it.
I took the antennas whip base, which is a male screw in antenna, into a female metal base,
out of the plastic antenna mount, and I want to put a new wire in it.
The antenna has a central core around a fiberglass stick.
The base has a small hole for the coax core, but no connection other than contact, for the ground.
The small + hole is too small for the core insulation around the coax core, so I am considering drilling the F.base' coax + hole to insulation size, then putting the coax ground onto the base with a little hole drilled for a screw.
The antennas contacts are shorted, in both the base and the antenna, but I remembered my basic antenna electronics and I have read something about antennas that are shorted out specifically and work that way on purpose...
Can anyone enlighten me on this shorted antenna design and how it is supposed to work so I don't short out my radio?
