I need a switch circuit to control a diy circuit using a 12v supply voltage. Current is modest at a max of 100ma. The control signal is a 0-8v pulse at a frequency of 50-400 hz. I'm thinking a JFET circuit because I don't want to load the source signal and I also want about a one second turn on/off delay. The high impedance of a JFET should accommodate both of those requirements. Also space is limited so small components are desirable, although I prefer to avoid surface mount devices.
I don't know much about JFETS and my basic question is what type of JFET is applicable (P-channel, N-channel, enhancement/depletion, etc.). I suppose a MOSFET may also work, but I only have a couple of power MOSFETs and their size is kinda big. Also I have a variety of JFETS in stock.
I have attached a rough sketch that may help show what I am thinking. I can figure out the component values I need, but I need some guidance on the JFET type.
Thanks
Frank
Thanks
Frank
