revolving chandelier with a way to plug in led strips
Crafts4Me
Feb 10, 2022
163
please explain the different number of channels what does it mean i found slip ring motors and hollow center etc but what is 4/6/12 wires?
Harald Kapp
14,290
Sorry, I was just kidding. While the motorized base is 110 V , it can be customized acc. to the website.
But: Has anybody had a look at the price?
I thought it would be obvious that this is not what the op wants.
Crafts4Me
Feb 10, 2022
163
what is the difference. sorry i am learning something new. what applications can be done with 2/4/6/12 channel/wire motors
what ditfference does the number of wires make? can i connect more lights etc?
Martaine2005
May 12, 2015
5,287
Yes you can.
They are different circuits. However, depending on the overall current requirements, you may get away with a single circuit.
I’m still interested in the inside of your existing unit. It may be quite simple to simply change polarity on the the motor for CW rotation.
Martin
Crafts4Me
Feb 10, 2022
163
its anx mas tree base, big and bulky and i cannot design the crowns lights thats why i wanted to create one all on my own
now i am struggling to understand the # of wires on the motor. what do they do and how do i connect my lights etc to them
Delta Prime
Jul 29, 2020
2,989
Well then, you better stop reading all of these suggestions. ;)
Is it possible to take a quick photo of the wires coming out of the motor.
Crafts4Me
Feb 10, 2022
163
please just a simple reply
i sent a photo of thw motors available
can someone explain what menas 4/6/12 etc wirs
what can i do with them
Crafts4Me
Feb 10, 2022
163
hi
post 25 isnt an naswer i dont understand
i have the motor
one end all 4/6/12 etc ar all connected to one plug
all the rest on the ring that turns
lets say 12 wires, i can add 12 electic led strips or 6 because each connection needs 2 wires?
Martaine2005
May 12, 2015
5,287
That is where the data sheet for your motor is very important.
You need to know the primary voltage and the secondary voltages. And if it shares a common ground. It may have secondary taps at different voltages too.
Can you share the link for your motor?.
Also, what LEDs are you wanting to use?. Voltage? Current? How many?.
Martin
hevans1944
Hop - AC8NS
Jun 21, 2012
4,984
can this be done?
Sure, almost anything can be done if you know what you are doing. It seems fairly obvious that you know almost nothing about electricity or electronics. And, in return, we know almost nothing about what you are trying to DO. Does it have something to do with trying to build and hang a rotating, LED-lighted, styrofoam "crown" from the ceiling without using an upside-down, motorized, rotating Christmas tree stand? Other than rotating in the "wrong" direction, and probably looking like a kludge, what's wrong with that? The parts list you finally posted (above, post #32) DOES NOT include a motor.
I am soooo impressed with the back and forth discourse as this thread continues to unwind. Perhaps this suggestion would help:
Help us to help you!
Give all the information you have instead of us keep asking you!
FLASH ALERT! Additional requirements (see post #20) have emerged: this contraption has to mount inside a hut's roof and needs to weigh less than 10 punds! No information on what kind of hut it is. Could it be a yurt? Still no mention whether the desired clock-wise motion is when looking UP at the rotating fixture, or looking DOWN at the floor from above the rotating fixture. Also no mention yet on how fast it has to rotate. Oh, wait! @Crafts4Me seems to think (see post #32) that this or that is a motor! Good luck with that!
Crafts4Me
Feb 10, 2022
163
correct i am a hobbyist and the most electronics I know is 12v strips, lights motors and fountains.
it seemed to work well till now
for the Holidays I built a lighted crown that hangs from the ceiling that slowly spins. I made it 7 branched for the 7 sheepherds (7 days of the week) to get it to slowly rotate between 1-20 rpm I used a rotating xmas tree holder however i hung it form the ceiling in an upsidedown fashion
it works well however a- its really bulky and takes up extra space, b- its the wrong voltage its 110 and I really need 220 c- it now turns ccw so my words kind of rotate backwards
i want to design a newer fancier better lit crown but was wondering if i myself can make the motor and holder so it better suits my need
since its foam core plus fabric it doesnt weigh more than 10-15lbs
Crafts4Me
Feb 10, 2022
163
i am sorry
i am coming back to this
i have my crown, 2 feet x 2 feet
lit with led lights rgb strips and individual mini lamps
all 12v maybe 10 pounds weight at most
i would like it to revolve
please advise what i need with motor and slip rings
i need it to be cost effective
please advise
tahnks in adavance
Crafts4Me
Feb 10, 2022
163
hi
i am still trying to do this and not succeeding
my hut is a sukkah. i do all the decorations on my own.
i made a new crown, it weighs between 5-7 lbs
i wired it with 12v lights it has an adaptor to 220v
i need this crown to revolve
please help me design a "DIY rotating tree stand 220v" using slip rings and motors that are reasonable priced (till $50) using slip ring and motor
thanks
the ready made tree stands are too big and bulky
