Sallen Key Low Pass Filter, bandpass filter
Maglatron
Jul 12, 2023
2,025
or is it before the pre-amp and after the voltage source? right now it goes up to about 750mV
bertus
3,869
Hello,
Place the voltage divider between the 45 Hz source and the preamp input.
Use a capacitor of about 10 uF between the voltage divider and the preamp input.
As the signal peaks at 0.8 Volts, use a 1:40 voltage divider.
Bertus
Maglatron
Jul 12, 2023
2,025
correct? this is the output so I think I have it wrong again this is the wave output1702325376830.png
Maglatron
Jul 12, 2023
2,025
so now its centered about 9v and not 6(I want it centred about 6v
bertus
3,869
Hello,
Now you can adjust the gain of the preamp to get the wanted outout.
Bertus
Maglatron
Jul 12, 2023
2,025
ok it's working well now thanks I just need to make another 15 filters
Maglatron
Jul 12, 2023
2,025
it now tops out at 6.3volts and after the pre-amp, and then after the amplifier it tops out at 7.3 volts can you help me edit the amp so to use the full 2.4volts ie 6v to 8.4v please
bertus
3,869
Hello,
Yes, you connect the mic to the power resistor R15.
When you raise the value of R15 to 12 K, you can use the preamp on 12 Volts.
Bertus
Maglatron
Jul 12, 2023
2,025
so like this! also can you help me edit the amp so to use the full 2.4volts ie 6v to 8.4v please what is the fastest schottky diode in the program?1702326746522.png
bertus
3,869
Hello,
When you connect the mic the following parts can be deleted:
V1 , R22, R18 and C18.
You can change the gain with R23.
I think you can go upto 470K for R23.
Bertus
bertus
3,869
Hello,
You don't need speed. You can select on voltage drop.
Shottky diodes wil have a lower voltage drop.
Bertus
Maglatron
Jul 12, 2023
2,025
high voltage drop seems to work better! is the 45 breakdown voltage what you are talking about1702327708734.png
bertus
3,869
Hello,
With a lower voltage drop, the evelope detector will follow the signal closer as a diode with a higher voltage drop.
Bertus
