Sallen Key Low Pass Filter, bandpass filter
Maglatron
Jul 12, 2023
2,025
the simulation black box with this circuit it take 2 mins to load and only shows 90ms, this black box!! simulating other circuits works fine!! it does it wherever you put the probe too1702295456445.png1702295286849.png
  • compiled filter along with lm3914.asc
14,317
O.K., so you mean the plot window showing the simulation results. Be aware that the simulator does not work in real time. Simulating a few milliseconds of real time can take seconds or minutes, depending on the complexity of the circuit. You need to be patient or try one of the fixes I linked to.
Maglatron
Jul 12, 2023
2,025
yes ok so I took out the lm3914 and it's working properly again - beautiful so I have determined that there is a problem with the lm3914 circuit!! just removing the cascaded LM3914's and their circuitry set it back to normal!! 1702296019129.png
  • compiled filter along without lm3914.asc
Maglatron
Jul 12, 2023
2,025
so I made the LM3914 circuit and added it again and its gone back to how it was only showing 90ms worth
  • compiled filter along with lm3914 ammended.asc
Maglatron
Jul 12, 2023
2,025
what is wrong!!!!???????? the program doesn't seem to like the LM3914 or the LM3915 chips, why only 90ms!!! this is becoming a big problem! It's like it has a time limit that I can't seem to change!!
Maglatron
Jul 12, 2023
2,025
can anyone solve the problem of the sim only running for 90ms, thanks
14,317
You solved it yourself: remove the LM3914.
There is no need to simulate this chip. All you need is the output voltage of the envelope detector and check it against the input specifications of the LM3914.
The LM3914 (or LM3915) is a fairly complex circuit and this is probably the reason the simulator stalls.
Maglatron
Jul 12, 2023
2,025
the envelope detector is showing this really thick line (it was thin before) can you help fix it1702315041231.png
  • compiling.asc
Maglatron
Jul 12, 2023
2,025
now it's not enveloping at all!!
actually, it is, it is just really thick envelope how do you make this better?? before and after1702317159101.png1702316590970.png
Maglatron
Jul 12, 2023
2,025
I took out the rariable resistor on the pre-amp and put a direct wire in its place this minimizes the gain I think but it still tops out at 9v which is larger than the desired 8.4v and havn't sussed the envelope detector yet! fixed it with a change of schottky diode!
Maglatron
Jul 12, 2023
2,025
I'm going through the different schottky diodes RB706F 40 is by far the best so far
Maglatron
Jul 12, 2023
2,025
how do I change the pre-amp so it give about 0.5 of a volt less then it will work safely with the LM3914?
bertus
3,877
Keep in mind that the output of a mic can be much smaller.
For the mic you probably need the gain.
The output of the mic will likely be in the range of 10 - 20 mV.
Read the following page for more info:
Scale the 45 Hz file for lower intensity.
Bertus
Maglatron
Jul 12, 2023
2,025
Hello again! ok is it possible to make a low scale audio file in audacity? did you manage to download the LM3914 to your library and how did it go for you I have a ryzen 5000 5 does it run on yours??
bertus
3,877
In Audacity you have the function amplify in effects.
With that you can make signals higher (+dB) and lower (-dB).
You could also use a resistor divider at the 45 Hz source on the input.
Bertus
Maglatron
Jul 12, 2023
2,025
ok this I can do,
so how do you adjust the voltage divider so that its in the 10 to 20 millivolt range (after the preamp but before the amp)
