okay so the initial force needs to be calculated that accelerates the weight (in the first 10% of the 2 second cycle) to the velocity that it stays at (for the remaining 90% of the 2 second cycle) - the force to keep it at that velocity till it reaches the top of the 1.32m, then along with the slope, what's the torque required given the cam has two lobes and at the widest radius of the cam is 0.45 and the lowest point is 0.318m and will make the scissor and weight move up in 2 seconds (the cam makes a full revolution in 4 seconds then weight is 0.2622kg and it moves up 1.32m, then when I have all the calculations made in a perfect system I will remove the losses due to friction inertia of the cam and the weight of the scissor, thanks Mr Alec_t
