I have a broken USB port on my Dell WD19TB docking station. Surprisingly, I have been unable to locate a replacement component. Most of the ones I have found have a fringe around the USB ports and I am not sure if that will be an issue with it physically fitting or not. I have found some that did not have the fringe, but looking at the data sheets, the dimensions might not fit. Also, those are from Alibaba manufacturers, which can be unreliable and frustrating to deal with. Additionally, getting one of the same USB standard can be an issue.
I honestly didn't expect it to be this difficult. I've looked at Mouser, Digikey, Newark, etc., looked at several parts search places, contacted Dell, Googled for hours. I tried most of the suggestions in the "Before you ask" post before I even came here, but tried some more. The part has S201509 stamped on it but that hasn't helped me. I am trying to find the exact part and manufacturer used only because I am concerned about it physically fitting as well as the USB spec being wrong and causing some unforeseen problem.
