audioguru2
- Apr 6, 2004
- 12,026
- Joined
- Apr 6, 2004
- Messages
- 12,026
Hi Guys,
The project is here:
http://www.electronics-lab.com/projects/games/003/index.html
I have a pic of my Veroboard layout. It has 47 (!) trace cuts which takes my drill-press about 2 minutes to do. It has 21 jumpers, a few under the ICs, that takes me abut half an hour to cut, bend and solder. It takes a while to solder the rest of the stuff on the board. See that I am using pieces of IC-socket to plug-on-to two LEDs that have their wires inside the box where it is crowded for soldering.
I had to be careful drilling the CD for the LEDs because it is fragile, my 1st one shattered all over the place!
I drilled the front of the box for the two LED holders to protrude through and routed-out the PCB support grooves at the sides to allow space for the pots.
I bought log (audio taper) pots for brightness controls and linear ones for speed control, but the linear ones were actually log type (marked wrong) so the full speed adjustment ends-up in the maximum 1/4 rotation of the pot.
I am busy making a bunch of these things for family and friends.
Corrected Nov.12/04
Corrected Nov.12/04
