7 led chaser 555 and 4017
Tony357
Dec 10, 2014
I have a 7 LED chaser circuit (BELOW) that i moded to get the results that i need.
Firstly I increased the voltage in the whole circuit from 9V to 18V then i added 2 BC108C's in the darlington pair formation after each output leg of the 4017b chip that i used, before each LED output.
I think i have blown the first transistors i used I have got new transistors which i believe turn on at 25V they are also BC108C's is there a way i can boost the voltage after the output pins of the 4017B chip to turn on my new transistors to give me the current i need, or would i be able to use another component to replace the Darlington pair with and get the same current gain.
This is the circuit i started with:
7-led-light-running-adjust-speed-by-4017-and-5551-600x530-jpg.76895
Ian
Administrator
Aug 23, 2006
1,486
Welcome to the forums Tony. I've moved this out of the project log section, as that is a showcase for completed projects, rather than questions :).
